straightening corner of chimney breast
macliam
by macliam » Thu Dec 06, 2007 10:59 pm
moved into house. one corner of chimney breast is off line - in 2" from floor to ceiling. I'd like to straighten it. Should I knock off the existing corner and restart. can i use finish plaster over existing painted plaster to make up deficit. should i use those angle pieces and skim over them. as you can see i am a complete illiterate when it comes to plastering (in fact most diy). any advice please?
toptips
by toptips » Tue Dec 11, 2007 11:42 pm
hi,get a length of 2"x2"timber to match the height from floor to ceiling. along the length mark a line from corner to corner.cut along this line and you will end up with two pieces of timber 2" running down to nothing. fix these to the side of the chimney then cover with plasterboard.dont forget to set the front piece back from the face of the chimney to allow for the plasterboard and a few mm of skim.
macliam
by macliam » Fri Dec 14, 2007 1:44 pm
not sure if i already replied. but thanks for advice. will try over the xmas break
It is currently Wed Nov 27, 2024 2:31 pm
