washing machine
robbo
washing machine
by robbo » Fri Dec 07, 2007 11:58 am
door lock on washing machine stuck on any help
mikekite1969
by mikekite1969 » Sun Jan 06, 2008 5:43 pm
Hi I have had this problem most machines have a cable attached to the door lock whiich is attached to a switch on the motor which useally releases the cable when the machine has stopped my cable became jammed as it had freyed inside the casing you should be able to get to it through the top of the machine make sure you unplug from the wall first if you are not sure how to do this I would call an engineer its quite straight forward and not very expensive.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 10:46 am
bell22
by bell22 » Mon Mar 29, 2010 7:34 am
Thank you for the information. As an added information, you can Google also "allwashingmachinereviews.com" for your reference. Good luck.
It is currently Fri Nov 22, 2024 8:38 am
