Bath Waste pipe
akey
Bath Waste pipe
by akey » Mon Dec 10, 2007 11:57 am
We are currently installing a new bathroom however the new bath plug is at the other end of the bath from the original one. This gives me 2 problems, the first is that the waste pipe run will need to be 2.5m to reach the existing soil stack. The second is that I would need to cut through a number of joists to run the new pipework.
Is this permissible or will I need to install an external waste pipe?
Any ideas would be much appreciated
peter the plumber
by peter the plumber » Tue Dec 11, 2007 3:26 am
The simple way to do this is to raise the bath or turn the bath around.
You can’t cut joist to 44mm they will not take it.
It is currently Mon Dec 02, 2024 5:46 pm
