by Oddbod »
Sun Dec 23, 2007 12:40 pm
Hi. If I picture what you are trying to do right it is the depth that is the issue for you. You have a 4ft deep space, with one straight side and one sloping side. If you just wanted narrow shelves you could simply use standard shelf brackets, but then you'd only get a about 1ft of useful shelf width.
OK, so on the somewhat optimistic assumption that I've got the plot...
You can easily fix battens to the vertical side of the space as per normal, simply screw lengths of 2 by 1, or 1inch square to the wall as far apart as you want your shelves.
You will have to bevel the wood for the other side. The easiest way to do this is with a circular saw – pick up a cheap one if you haven't got one. (IMHO It's far more useful than the ubiquitous jigsaw which can't cut a straight line whatever you do with it!). Set it to cut at a 40 degree angle (which should be close enough to the angle of your stairs, but you can measure it if you're feeling accurate!)
Then cut 1 or 2 inch thick strips off a plank of 1 inch thick softwood. Cut these to 4ft length and you should find you have neat looking battens you can screw to the sloping side.
Finally use the saw to trim the ends of the cross-battens to the same angle on the sloping side (cut a whole load at once, it's easier) and the whole thing should fit quite nicely.
Last tip, chances are the sloping side is just plasterboard with nothing much behind it. Secure the battens with proper plasterboard fixings.
