Ceiling light fitting - what is it?
fire
by fire » Tue Dec 11, 2007 5:15 pm
Hello all.
I've just moved into a new place and need to replace a ceiling light fitting since it is clearly broken and the wires are exposed.
Unfortunately, I'm not sure what the light fitting is called so I've been having trouble finding a replacement.
Basically, it's a normal ceiling rose (fed with ring cables and switch cable) but it seems to have an integrated light batten lampholder. I can either find ceiling roses or batten lamp holders online but not an all-in-one. Any advice would be appreciated.
I'd like to replace it with the same thing but otherwise I may change the style of lamp to a flush lamp, put a junction box in the roof and just feed one l/n/e cable to the lamp.
Many thanks!
333rocky333
by 333rocky333 » Wed Dec 12, 2007 7:13 pm
sounds like a BATTEN HOLDER most are made like that now as opposed to the older BATTEN HOLDERS which were smaller and originally desighned to fit on conduit boxes, look on net at a mk 5144 whi and see if thats what you want, if so same or similar available at most wholesalers
fire
by fire » Fri Dec 14, 2007 5:03 pm
Super thanks. Part acquired and fitted successfully.
333rocky333
by 333rocky333 » Sat Dec 15, 2007 4:06 pm
More room for wires ,and easier to fit,glad your sorted.
It is currently Sat Dec 28, 2024 6:11 pm
