Radiator Size list
TONYTONE
Radiator Size list
by TONYTONE » Wed Dec 12, 2007 12:37 pm
Hi guys,
Does anyone know of a website that will allow me to trun my watts values into physical radiator dimensions. I've done all the calcs but the lists that I have found so far have limited size ranges.
peter the plumber
by peter the plumber » Wed Dec 12, 2007 5:13 pm
Sizing radiators is not an easy thing to do. Location is important too.
You need to know a bit more than the sites tell you.
There is a site for this, but if you don’t know how to use it, it’s a waste of time.
Here the basics
The term “U valueâ€
TONYTONE
by TONYTONE » Thu Dec 13, 2007 12:21 pm
Cheers for the info. I fortunatley have already done all the calcs to give me my watts per our etc. What I need now is a list of physical radiator sizes with their relevant watt value i.e double rad at 600H x 1200 = ???watts. The only lists that I have found so far have limited sizes shown and I need to see what options are available so I can see where they can fit in my house.
peter the plumber
by peter the plumber » Thu Dec 13, 2007 2:19 pm
Not all radiators are the same.
If you look at a Stelrad Radiator Compact 600mm High x 1200mm Wide
You will fine their 4 models
k1 1176 watts
k2 2078 watts
p + 1614 watts
p1 743watts
You need to know what you are buying and why.
If your just buying just one radiator it don’t matter if you make a mistake, but if your buying more you can easily find yourself in trouble.
Get hold of a myson brochure and have a look thru it.
TONYTONE
by TONYTONE » Thu Dec 13, 2007 5:40 pm
Cheers pete. I'm on it
It is currently Wed Jun 26, 2024 7:55 am
