Fixing Ramp Profile / Reducer
seliamitabh
by seliamitabh » Wed Dec 12, 2007 11:35 pm
h,i need some help to fix a ramp strip / reducer . the issue is that the height between the floors is about 19mm and the ramp profile/reducer i have found has a height of 9mm and hence can cover only a height difference of 9mm.
is there a way to avoid fixing an additional strip of wood under the reducer to fi the ramp profile as it will be very hard forme to get the height right with the additional block of wood underneat the reducer/profile .
plsadvise !!
It is currently Mon Dec 23, 2024 6:28 am
