serface mounted sockets and wiring?
colscastle
by colscastle » Fri Dec 14, 2007 10:54 pm
Hi my house was built in the 1950s and over the years has had extra sockets added, which are serface mounted with the wiring cliped to the skerting board. What i want to do is replace the sockets with flush ones, and let the wiring in the wall and then plaster over it. The CU has been renewed with a modern rcd one if i do this work myself will i need it checked in regard to part `P`. We have just brought this house after having modern houses before and are looking forward to doing different jobs so i shell be asking other questions no dought.
by sparx » Sun Dec 16, 2007 10:37 pm
Hi, unless in 'special location' ie kitchen or bathroom[unlikely] then you can diy this work as not adding to circuit. no need to report or get it certified.
take care, leckie takes no prisoners!!!
SPARX
colscastle
by colscastle » Mon Dec 17, 2007 10:41 pm
thanks for that its not in the kitchen or bathroom so i should be ok
It is currently Wed Jan 15, 2025 7:44 pm
