copper to plastic
splashy
copper to plastic
by splashy » Sat Dec 15, 2007 9:06 pm
Mine's quite a simple query..connecting copper pipework to plastic,as in hot and cold copper feeds being plumbed into a plastic bodied thermostatic shower unit.
Any particular potential problems to bear in mind?
Cheers.
Chelsea Cruiser
copper to plastic
by Chelsea Cruiser » Sun Dec 16, 2007 10:15 pm
I assume that the copper and plastic pipes are both the same size .ie- 15mm .. The cleanest, quickest and easiest way is to use Speedfit, these are available as straight couplings, elbow, tees and reducers. They are made of white plastic suitable for hot and cold supply on both copper and plastic. These simply push onto the pipes..job done, they are also de-mountable and re-usable, The only drawback to Speedfit is that are a little bulky. If you are tight for space you can also use brass or chrome compression fittings but be sure that the plastic pipe is 100% clean and scratch free otherwise they could leak especially under mains pressure.
splashy
by splashy » Tue Dec 18, 2007 5:07 pm
thank you very much,CC
marrtin
by marrtin » Tue Dec 18, 2007 9:56 pm
Hep2o fittings are similar to Speedfit but much smaller and unfortunately available only in grey. Once fit, unlike Speedfit, they cannot be removed.
splashy
by splashy » Thu Dec 20, 2007 12:15 am
Cheers,marrtin--as Ive explained on another thread,I'm going to stick with using the original Aqualisa fittings for this job.
It is currently Sat Nov 16, 2024 6:11 pm
