Leaking Radiator
diysteve
Leaking Radiator
by diysteve » Sun Apr 08, 2007 12:57 pm
I've just found that my radiator in the front room has a small hole and is leaking,
if i follow the steps to isolate the radiator and stop before i disconnect it completely i assume this will stop any more water going in to it to leak out. Is this correct?
If this is correct will the rest of the heating still work if i switch it on tonight?
Also cananyone recomend any puty/ sealant i can apply on the outside of the radiator to seal the hole?
Steve
strevs
by strevs » Wed Apr 11, 2007 9:52 pm
if rad valves hold then no more water will get in....but is an if..
heating can be used....DIY stores stock what you need but can be a bit iffy to rely on long term....due to pressure and expansion
It is currently Sat Nov 23, 2024 6:41 pm
