by Tall Tone »
Sat Feb 09, 2008 1:56 pm
Hi Gizmo
I personally have no experience with this product although I have seen samples at my local distributor. I am sure it would work I am just a little dubious as to how long it would last.
As for having a long edge in the middle of the room, you could use a flexible adhesive to allow a little movement, look at Sika T54 or Bona R850. If the boards are very wide or the area very large you may need to mechanically fix
If the problem is height or not wanting to use a ply base, which ever way you choose you need to ensure the concrete floor is level to the requirements of the wood manufacturer (or British Standard) and also within moisture tolerances and dust free. You may also need a primer or DPM.
Regards
TT
