concrete over and around concrete
learner
by learner » Mon Dec 17, 2007 9:25 pm
I am demolishing an old shed and having a new one built (9mx6m). The new building is larger than the old one and I therefore need to make the existing concrete base bigger. I also want to raise the level of the new base slightly as well as increasing the overall area so there will be new concrete on top of the old slab as well as at the side of it. Are there any special considerations for doing this? I was going to dig out the new perimeter, add compacted aggregate and then pour to the new level of the base....is that ok? Will it bond ok? Thanks for any advice.
Rob
grooverider991
by grooverider991 » Tue Apr 01, 2008 7:10 pm
ok,what your doing is ok but cover the area with reinforcing mesh then concrete over the entire area,this will bind it all together.Make sure you suspend the mesh to allow concrete to flow around it,half an inch will be ok.Hope this helps
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 26, 2010 8:45 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sun Nov 24, 2024 12:01 am
