Kitchen Light causing problems
crwort
by crwort » Tue Dec 18, 2007 8:43 am
Hi i have a problem.
I just replaced a kitchen ceiling light (all wires replaced as they were in the original light fitting (3 black to neutral, 1 red to live, and 3red + 1black together)).
The Kitchen light works fine but now the hall and lounge light don't work. I have checked all the connections again to make sure they are tight and proper - and they are!?
I had the hall light switched on during the work (but off at the breaker) but i didn't try the lounge light until i had switched it all back on again.
The other downstairs light still works ok as do all the upstairs lights.
Any advise gladly welcome.
crwort
by crwort » Thu Dec 20, 2007 2:04 pm
Problem sorted.
Tested all cables into kitchen to find out which ones were which.
Power in, Switch, Dining Room and Hall.
After that i found that it was a broken black wire between the kitchen and hall about an inch up from the light fitting neutral terminal.
Repaired and re-wired now all lights work ok.
It is currently Wed Jan 15, 2025 6:53 pm
