coving cutting 45 o (degree) internal angles
boab
by boab » Wed Dec 19, 2007 1:30 pm
how do you cut 45 o angles on coving? iv seemed to get hang of 90 o internal and external cuts, but this has got me stuck. please help
Holywood
by Holywood » Sat Dec 29, 2007 12:04 pm
Sorry don't have an answer but I suggest you log this query under carpentry/joinery as a joiner will best give you the answer you need rather than a plasterer. This is the sort of problem many joiners will have come across only in wood so the same principles will apply.
Good luck.
kbrownie
by kbrownie » Sun Jan 06, 2008 11:49 am
Hi boab, There is a project under "angles" in the DIY PROJECTS on this site, it will give you a better idea and description with diagrams than I can!
Best of Luck
KB
by htg engineer » Sun Jan 06, 2008 12:22 pm
never cut 45o angles for coving but have for skirting -
like 2 - 45o cuts = 90o
2 - 22.5o cuts = 45o
can't see why it wouldn't work with coving too.
thedoctor
by thedoctor » Sun Jan 06, 2008 3:45 pm
See also the project on coving. Cutting coving angles is slightly different because the coving has to be the same way up for all cuts.
It is currently Sat Nov 23, 2024 11:22 pm
