Insulating under ceiling under large area of flat roof
egamar
by egamar » Fri Dec 21, 2007 4:03 pm
Hi everyone
I have a large are of flat roofed accommodation (dining room 22m2, kitchen 14m2 and Utility room 9m2). The existing insulation over all the flat roof area appears to be 1â€
Chippe999
re - insulating under a large flat roof/ceiling
by Chippe999 » Sat Dec 29, 2007 6:21 pm
First of all, is your flat roof a "warm", or "cold" flat roof? In other words, does the insulation lie on top of your ceiling in between your roof joists("cold"), or is it positioned on top of your roof boards (the ply boards that are placed on top of your roof joists(warm))? If you have a cold roof then you can either:
- Pull down your ceiling and replace the existing insulation (but beware you don't restrict ventilation through the roof space, or you run the risk of condesation in the roof rotting your joists and coming through your ceiling boards).
- Install a suspended ceiling, either plasterboard, or acoustic tile (we'll come back to this later*).
- Convert your cold roof to a warm roof by taking up your roof felt etc and putting an appropriate insulation between the roof boards and the felt (+ any vapour barriers deemed necessary). Then relaying the felt.
*With a suspended, or lowered ceiling, you must consider more than just how to secure the 150mm 'batten', since timber 150mm isn't batten its a ceiling 'joist'. Joists are a functional and structural part of a building whenever they are under load, so, must comply with building regs. Consequently, joists must be installed according to regs, which will involve building them into the internal skin of your cavity wall, or position them using joist hangers. Either way you will have to break into the internal skin of your property, thats assuming you have an internal block inner skin, and that your house isn't timber frame, otherwise you had best call in someone who knows timber frame. Also...you have to consider the span of a joist, as this determinse its actual size, i.e. 6"x2" or 8"x2", obviously the larger the span the larger (infact taller) the timber used. Once again building regs are involved.
Of course you do have the option of running 38mm square 'batten' at 600 csc, to run at right angles to your existing joists, across your ceiling. You could fix the batten to the joists at every point they cross, using a 4" nail, angle driven, or long screw. Then fill the cavity with some insulation and have a trade board the ceiling with insulation backed plaster board.
The easiest option you have is to install a 'drop' ceiling. using acoustic tiles, all you will have to watch out for there is that the metal wire supporting the metal grid the tiles sit in is firmly fixed to your ceiling joists. Also, unless you exclusively have wall lights, you will have to drop your rose to the new ceiling height. You could insulate above the tiles, but they are pretty effective on their own.
Whatever you decide to do, remember ventilation.
egamar
by egamar » Wed Aug 20, 2008 1:11 pm
I'm so sorry not to have thanked Chippe999 for his helpful advice - I'd lost the bookmark! I still haven't done the job, so the advice is just as valid now as it was then. Thanks!
It is currently Sun Dec 22, 2024 12:55 pm
