I have a good one which I wonder if anyone can help with?
Our central heating system is powered by a baxi boler which we have had serviced a number of time and which appears to be working fine. The problem however is that about 6 months ago you could hear the water running through the system - like trickles - which got progressively louder. To 'rectify' this (rightly or wrongly), I topped up the small tank in the loft (which apparently has something to do with the heating system) so that a pipe which hangs above the tank was immersed in the tank - I did this as I assumed that air was getting in to the system via this pipe and assumed that there shouldnt be an open ended pipe anywhere in the system. Having then released the trapped air from the radiators it definately appeared to cure the problem. However then a month ago a radiator started leaking - a small pinhole appeared near the top. I fixed this with some diy putty specifically for the job. Then 2 weeks ago, a pipe next to the hot water cylinder sprung a number of pin hole leaks. We got the emergency plumber out who replaced the pipe but he was only a young lad and by his own admission wasnt a heating expert. He said that the pipe was hot and shouldnt have been and that there was something wrong with the heating that probably caused it. He also said there was a problem with a device that is attached to the pipes which lies next to the cylinder and which he says controls the hot water and the central heating. (this looks like a small square box with a switch underneath it) He also emptied water from the small tank so that the pipe that I immersed is now open again and as a result the gurgling has restarted. I have also noticed that the small tank is full of dirty water - not clean - surely this isnt right? And to top it all the fuse in the heating clock has blown twice in the last 6 months. And just while Im at it the water is constantly hot no matter what temperature the boiler is set at. Any ideas anyone?
