Drives, paths and patios
thedoctor
by thedoctor » Fri May 26, 2006 11:48 am
To post a question for a Diy Doctor tradesman or your fellow users, to answer please click on “New Topicâ€
Jimmyvan
by Jimmyvan » Fri Mar 02, 2007 1:29 pm
Re Laying a drive on clay - trying to locate a heavy duty mesh underlay, water permeable, that is layed after excavation and before scalpings are laid. Allows water to drain through but keeps scalpings in place and helps prevents the drive sinking away. Used it several years ago and drive in good shape, but can't seem to find the same material. Recommendations?
EMDEC
by EMDEC » Wed Mar 14, 2007 11:23 pm
Where did you find the heavy duty mesh underlay before? Perhaps if you directly contact a local supplier they'll be able to help locate what you've used previous.
John
thedoctor
by thedoctor » Fri Mar 16, 2007 12:37 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sat Jan 04, 2025 11:57 pm
