by DONFRAMAC »
Sun Dec 23, 2007 11:08 pm
My last boiler had an overtemp. trip of 72 C, vented system, indirect cylinder, 210 litres hot water.
The diverter valve is your main suspect ; --- stuck valve spindle/blown motor, leaking gland can cause both.
OR, has someone switched on the immersion element.
Checking the thermostat on the side of the tank is the first task, easy for a competent DIY'er, with the whole boiler system isolated.
