central heating manifold
grizzlybare
by grizzlybare » Thu Dec 27, 2007 8:34 pm
Hi fitting Bosky solid fuel boiler require manifold to connect boiler to radiator who can supply.Cheers
Chelsea Cruiser
by Chelsea Cruiser » Fri Jan 04, 2008 10:52 am
I have a speedfit manifold which consists of two brass 22mm feeders and each has six 15mm take offs. It is mounted onto a steel bracket. It was very expensive but is now surplus to requirements. If this will help you out it can go on the cheap.
It is currently Sat Dec 28, 2024 10:37 am
