To Pump or not to Pump?
6 posts   •   Page 1 of 1
Big_Dave
by Big_Dave » Sat Dec 29, 2007 5:52 pm
I live in a single storey flat where the cold water to all appliances is mains. Hot water is via a gravity feed from a cold water tank in the flat (height to top of water in tank approx 2.3mtrs) into a copper cylinder with immersion heater. As you might guess, the flow is pathetic! I have bought a Stuart Turner Monsoon 2bar negative pressure pump to install via an ******* Flange and insert in the system to pump all appliances per manufacturers instruction. So far so good.
My problem is that a "friend" has told me that he was advised not to pump a system where the pipework is over 3 years old or hidden in walls or concrete floors due to "Possible splitting of the pipe or joints blowing". My pipework is 25 years old, copper throughout and as far as I can see soldered fittings.
Do I heed his advice and put up with hot water dribble or go ahead!
Sorry for such a long post but I'm desperate!
All comments gratefully received.
Big Dave.
by htg engineer » Sun Dec 30, 2007 6:15 pm
Whats the other options ?
Are you planning on fitting a shower, or is it just for a bath and washing ?
Would an electric shower be better ?
If you're thinking about re-piping it, is it worth trying it first ?
all may be well. If not your only back to square one - having to re-pipe it.
Why don't you pressure test hot water pipework first, using a test tee, hand bellows and u gauge ?
Hope this helps,
Big_Dave
by Big_Dave » Mon Dec 31, 2007 9:21 am
Thanks for your post.
The flat has 2 bathrooms, one with shower, WC and WHB, the other with bath with shower over, WC and WHB. Both the showers are Mira electric via mains supply so no problem. The problem area is the HW supply to the exixting 2 WHB's, the bath and kitchen sink.
Therefore all piping in place and 99% hidden and buried in concrete floor or walls. If my "friends" info is correct and to pump the whole system COULD cause a problem I suspect I'll give it a miss. Air testing might give me the answer but if it fails then I'm in trouble again trying to find the leak!!!
Would a small pump adjacent to each appliance pulling the water to one appliance from the open vented CW tank and copper cylinder rather than pushing it round the whole system put the same strain on the pipework?
Thanks for your help thus far.
bobplum
by bobplum » Mon Dec 31, 2007 6:52 pm
why not speak to the manufacterers and seek there advice
Big_Dave
by Big_Dave » Tue Jan 01, 2008 10:37 am
Will do. If I glean anything useful I will post same.
Thanks.
marrtin
by marrtin » Tue Jan 01, 2008 1:44 pm
One point worth mentioning, is that pumps are designed to push not suck water so fitting them at the appliance end may cause unexpected problems.
I am not sure you should worry too much about the risks of a leak. Don't forget the pipes will only be under pressure when the pump is running, and as you will be drawing water so that alone will restrict how much stress the pipes are under.
It is not written in stone that you WILL have a problem. In fact the odds are heavily on your side even if you were fitting a combi running at more than 4 or 5 bar. Remember the pipe will only fail at a weak spot. It may fail tomorrow anyway.
It is currently Sat Dec 28, 2024 10:10 am
