bathrooms
kingsland
bathrooms
by kingsland » Sun Dec 30, 2007 2:12 pm
who makes the best quality shower tray, lots of heavy lads in our house so it needs to be robust ,purchased cheaper one in the past and regretted it[/b]
chris_on_tour2002
by chris_on_tour2002 » Sun Dec 30, 2007 6:36 pm
don't go for a plastic one, go for stone resin. more robust but more involved to install. best way is to lay marine ply then bed the tray with cement. a bit of a faff but good and sturdy. any local plumbers merchant should be able to order one, there are a few manufacturers and they seem to be much of a muchness in terms of quality.
marrtin
by marrtin » Sun Dec 30, 2007 11:41 pm
As Chris says, resin stone is what you want. Some have optional legs. Don't bother. Just use 18mm marine plywood. If the tray needs raising, stand the ply on 3" x 2" or 4" x 2" battens set 6" apart so the tray is fully supported.
kingsland
by kingsland » Mon Dec 31, 2007 10:38 am
thanks very much for your reply and sound advice will order a stone resin one this week
It is currently Thu Dec 26, 2024 12:15 pm
