by 333rocky333 »
Sun Dec 30, 2007 3:24 pm
Is the switch a single 1 gang and is it 1 or 2 way
check what wires are in that switch
Your new light possibly should not join to the two reds these will be left joined on there own.
It would seem thats why it is on when the switch is off as you used the reds and is blowing when switched possibly because you have also joined the switchlive yellow to earth !!
OR
It may be the blue was used as the switchlive instead , and the yellow was parked up unused ,this would do the same as above, as you have joined the BLUE to neutral.
Check what colours are used in the switch.
Your yellow is proberly not earth ,test to see if it is live or becomes live when switch operated
Do same with blue but may read as live if it is a neutral returning from elsewhere so may confuse you.
When sure what is switchlive use as live to the new light
As for the blue this may be in use as a neutral or a switched live ,
you need to locate the other end to determine what it is being used as.
Proberly best to leave this blue parted from the neutral till you sort out the other cores, and work out what it is for, the blue or yellow ,may not be in use within the switch, but you do NEED to locate it.
And either connect or seal off safely !
When you do locate the switchlive mark it red or brown to assist in the future
