Karndean flooring
frankino
Karndean flooring
by frankino » Sun Dec 30, 2007 7:59 pm
I am about to have Karndean flooring fitted in bathrooms by installer.
Should the toilet bowl be lifted to allow fitting underneath, or is it normally just fitted around and sealed?
Thanks in advance.
tav
by tav » Mon Dec 31, 2007 3:14 pm
mostly it is fitted around toilet then sealed .if you fitted it under toilet it would be a neater finish but may affect the pipe work slightly depends on the toilet . and if you had a flood the toilet would have to come out again if it were under .
It is currently Sat Nov 23, 2024 5:33 am
