dry lining and painting
Holywood
by Holywood » Wed Jan 02, 2008 6:01 pm
I'm thinking of drylining a back room, sanding and painting. Can anyone confirm please that I can still get this skimmed even after painting with emulsion if it doesn't look good enough?
Thanks for any help
kbrownie
by kbrownie » Wed Jan 02, 2008 10:10 pm
Hi Holywood,
Yes you can skim over paint as long as you prime wall with PVA,
but if you dryline wall with tapered edged boards and apply tapes and compond correctly, sand down and prime wall for painting you should not have problem. You will need to fill joints out 2 or 3 times.
Good Luck
KB
Holywood
by Holywood » Sat Jan 05, 2008 6:33 pm
Thanks KB I'll give it a try.
It is currently Sat Nov 23, 2024 11:46 pm
