im fitting a new combi boiler and.......
7 posts   •   Page 1 of 1
dog
by dog » Wed Jan 02, 2008 6:28 pm
wondering if someone can tell me the building regulations in fitting this system.
i want to put the boiler in the kitchen and to plumb into the existing radiators
thanks
marrtin
by marrtin » Sat Jan 05, 2008 12:10 am
First of all can you please confirm you will not be fitting the boiler yourself as this would be against the law, dangerous and will invalidate your house insurance let alone put you in line for a hefty fine or prison sentence.
by ericmark » Sat Jan 05, 2008 5:20 am
Think it comes under Part L
kbrownie
by kbrownie » Sat Jan 05, 2008 6:31 pm
Hi dog,
can't fit new combi boilers anymore, have to be condensing boilers.
Need Corgi registered gas fitter to carry out work.
Regard
KB
coupedummy
by coupedummy » Sat Jan 12, 2008 3:45 am
Kitchen is fine to fit,
condensing boiler is a requirement to be fitted under part l but some extremly rare incidnces a standard combi can still be fitted.e.g where no phyiscal routing to drainage for condense is possible and any position of fitting boiler.doesnt any apply to any ive seen tho as position boilers can always be moved.
Condense drain must go to sewage waste drain and not storm drains.
gas must be connected and boiler commisioned by qualified corgi fitter.
boiler to be installed and commisioned via manufactuars instructions always!
by ericmark » Sun Feb 03, 2008 2:45 am
A combi boiler can be condensing or non condensing and a condensing boiler can be combi or standard.
Combi means it instantly heats hot water and no hot water cylinder or cistern is required.
Condensing means the exhaust gases are cooled to a point below boiling point and the latent heat of evaporation is used by the system. Some systems even use heat pumps and a three stage system to extract the last drop of energy but I have not seen them for sale in UK.
There is a third label either open or closed system most modern combi condensation boilers are closed system. But open systems are available in both combi and condensation systems.
Because duel fire/boilers or back boilers can be in the centre of a house condensing boilers can't be used because not really possible to relocate but to not use a condensation boiler would be silly unless something like that prevented it so they are not stocked and very hard to get one that isn't condensation type.
Who fits what is now becoming a problem as the plummer can no longer do the electrical part nor can the electrician do the gas part it seems that after years of trying to get workers to do work on allied trades to which the unions fought hard to stop it is now the government it's self who have returned us to one man one job again.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 10:41 am
It is currently Fri Nov 22, 2024 10:28 am
