Low Hot Water Pressure
johnrbaxter
by johnrbaxter » Tue Apr 10, 2007 9:17 am
My daughter owns a flat where the hot water to the sink basin and bath comes from a cylinder with immersion heater.There is a small open tank above the cyinder with ballcock.All cold water supplies are directly from the mains pressure which is very high.The hot water pressure is very poor.Is it possible to fit a pump to circulate the hot water in these circumstances or is a more comprehensive solution required?
markp
by markp » Sat Apr 14, 2007 8:32 am
its because the feeder tank is right above the cylinder move the little tank higher and you will get more pressure^^ otherwise its no better than a combination cylinder
markp
by markp » Sat Apr 14, 2007 8:38 am
the little tank needs lifting higher to give a better rate from the cylinder,as high as possible really
It is currently Sat Nov 23, 2024 11:04 pm
