fire doors
stew42
fire doors
by stew42 » Sat Jan 05, 2008 8:40 pm
Hello
Can anyone help. When a loft conversion has been completed do the bedrooms on the first floor need to have fire doors fitted.
Stew
thedoctor
by thedoctor » Sat Jan 05, 2008 9:01 pm
Lofts are a long way above the ground, so you should consider fire escape routes. If you have a two-storey house, you will have to replace the existing doors around the whole staircase (except those to non-habitable rooms like bathrooms and cloakrooms) with fire- resisting doors, to make a fully-protected path to the ground-floor exit. The new room(s) in the loft also need to be provided with fire-resisting doors. Any glazing in the walls enclosing the stairs will also need to be replaced with fire-resisting glass.
If you have an open-plan layout, you must put in walls to separate your stairs from any rooms, and link them to an escape route to the outside.
Until April 2007, all doors to habitable rooms off the stairwell had to be provided with self-closers. You no longer need to do this, but everyone in the household will now have to be much more aware about the need to keep doors protecting your escape route closed, especially at night.
LCL
by LCL » Sun Jan 13, 2008 8:31 pm
stew42
In a conventional two storey house loft conversion which i beleve yours is, there needs to be a protected route between the bedroom(s) door to the second floor level and the point where saftey is reached, normally the front door or access to the external parts.
Some building inspectors will accept automotic door closers fitted to all habitable room doors off this route, ie bedrooms, living rooms, plus the kitchen. Some, unfortunately will ask for fire rated doors to be installed. Any glazed doors will definately have to be replaced.
Hope this helps.
LCL
rhindesmith
Loft Conversion
by rhindesmith » Tue Apr 29, 2008 3:20 pm
We have a typical Victoria Terraced House in London. We bought the house last february (07) and it was already a 3 floor home, with the converted loft being a bedroom and bathroom.
Non of the doors in the whole house are fire doors currently.
We have just had a mansard loft conversion added on the same floor ( now there are two bedrooms and a bathroom).
There are 3 doors leading to the top of the stairwell.
Our building control guy has just done a complete about turn and now we have to put fire doors through the whole house...........
The rest of the house has the original doors.
The original mansard / canted loft conversion was done in 2000
Can you help
It is currently Sun Dec 22, 2024 2:48 pm
