by htg engineer »
Thu Mar 20, 2008 9:41 pm
I think a Combi boiler would suit your needs, as you have said you use an electric shower, so why heat a large tank of water for washing dishes etc etc ?
A combi will cope with the 8 radiators easily, will fill a bath, and you have the option of fitting a thermostatic shower.
As for the siting of the boiler, the pipes needed are:
Flow
Return
Gas already in kitchen
Cold Water Inlet already in kitchen
Hot water outlet already in kitchen
Pressure relief through outside wall
Condensate discharge to drain (kitchen)
I would guess the kitchen would be the best and easiest place to install a combi.
The flow and return can be located anywhere, depending on if you're wanting to re-pipe (recommended for age of pipework) or use existing pipework ?
