Flashing in Light Switch
toad01902
by toad01902 » Tue Jan 08, 2008 8:34 pm
Sometimes when i turn off the kitchen light at the switch there is a blue flash, is it badly wired up or something more serious, the house is only 20 years old.
by sparx » Tue Jan 08, 2008 9:56 pm
Hi most likely you have a highly inductive load such as fluorescent light or halogen downlighters? if so change switch for good quality type rated for inductive loads or try to find one with a 10A current rating on it,.
The blue flash is the contacts arcing due to a slow-break action, it will only get worse with age/use so don't leave it too long, I have seen holes burnt through to the front of switches due to thisregards SPARX
It is currently Sun Jan 26, 2025 2:50 pm
