hot water but central heating not working. Worcester combi 2
richard101
by richard101 » Wed Jan 09, 2008 8:18 am
I have a Worcester 24i combi boiler. Hot water is working normally but central heating won't switch on. There's a slight clicking noise, it's as if there is no spark to egnite gas.
Please help.
Thanks Richard
by htg engineer » Thu Jan 10, 2008 4:54 pm
If it's sparking to light the gas when the hot water is on, then the ignition is ok.
Is the room thermostat and programmer calling for heat ?
Does the pump run ?
Does the fan run ?
Follow the sequence diagram in your boiler manual. It will lead you to find what part is faulty.
It is currently Sat Dec 28, 2024 12:33 pm
