removing headgear from taps
simpleton
by simpleton » Wed Jan 09, 2008 1:21 pm
Hi, the hot tap in our bathroom has started to drip persistantly. I decided to take the tap apart myself and possibly fit a new washer. Its a pillar tap, and once I got the shroud off I found I couldnt undue the nut that holds the headgear to the body of the tap (hope this is making sense) When I try to turn it the tap starts to turn. It seems to be seized up. Somebody at work told me to apply heat to it but im unsure of what he meant. Does anybody have any tips for removing stubborn headgear?? I dont really want to shell out for a new set of taps so any advice would be appreciated
Chris
marrtin
by marrtin » Wed Jan 09, 2008 8:50 pm
It's not uncommon to get the whole tap turning when trying to gain access to the washers. Get someone to stop the tap from turning while you apply force to the nut. Don't go anywhere near it with heat unless you want to destroy the tap.
Gus
by Gus » Wed Jan 09, 2008 9:35 pm
You need to protect the tap spout with a cloth and then put a wrench on it so the wrench is perpendicular to the tap and then use a big adjustable spanner on the nut. a bit of WD40 will help things along. I wouldn't use heat unless you really have to.
simpleton
by simpleton » Thu Jan 10, 2008 7:09 pm
Thanks fro the advice, I managed to dismatle the tap using the biggest wrench I could find and some stillsons wedged on the spout to stop it moving.
Apparantly another good thing to do is to drill two holes in a board of wood roughly where the tap spouts are and put this over them both this stops the taps moving.
thedoctor
by thedoctor » Thu Jan 10, 2008 8:47 pm
See the projects section with everything fromrepairing a dripping tap to repairing a supatap. All instructions + images are there
It is currently Tue Nov 26, 2024 3:54 am
