hot water in expansion tank
davelucas
by davelucas » Wed Jan 09, 2008 1:42 pm
i have recently moved house to discver that the expansion tank water is getting so hot it is causing codensation in my loft help :?
cyclop.orangehome.co.uk
by cyclop.orangehome.co.uk » Wed Jan 09, 2008 8:16 pm
baby died recently due to v.similar scenario i.e.exp.tank filling with hotter andhotter water until tank failed and flooded room below with boiling water-cause?-faulty thermostat-TURN OFF WHOLE SYSTEM NOW-ring for plumber
bobplum
by bobplum » Thu Jan 10, 2008 9:25 pm
dave how did you get on
bob
davelucas
by davelucas » Fri Jan 11, 2008 8:27 am
many thanks sorted thermastat and host of other probs really sorry to hear of your lose. thanks for your intrest bob
rosebery
by rosebery » Fri Jan 11, 2008 10:46 am
Sounds like it's pumping over. Boiler stat highly likely in which case you need a CORGI RGI not just a plumber. Could be a pipe blocked with debris and rust. In any case you should get it looked at.
It is currently Tue Nov 26, 2024 3:31 pm
