DEFECTIVE DIMMER SWITCH
MICK S
by MICK S » Thu Jan 10, 2008 1:17 pm
Can anyone tell me where I can buy the actual plastic dimmer swith units, rather than the whole Brass Plate and swith(es)
by ericmark » Thu Jan 10, 2008 3:22 pm
You can get them from Radio spares but it will cost more than ready built unit you buy and select the little blue thing can't remember name off hand the select the resistor pot and knob. I have built them into machines in the past also you can get grid type also but can't see why you would want to as it costs so much more than the china assembled ones available so cheap.
by ericmark » Thu Jan 10, 2008 5:03 pm
Found it. It's called a IC,regulator,power,phase-angle,10A,large-tab,CSR1004B
These cost £16 plus vat and don't include the pot.
Pot for 230 volt 250K at 1 watt
333rocky333
by 333rocky333 » Thu Jan 10, 2008 7:39 pm
usually cheaper to buy the white version with the same size spindle.
un nut it and fit on your old brass plate , carefull not to scratch brass and reuse old brass knob
Home automation 400watt ones are usually seperate modules with a push on/off spindle, if you want two buy a two gang,
MICK S
by MICK S » Fri Jan 11, 2008 11:01 am
Chaps
Thanks for replies.
Can't believe the price of the plastic bits !
Yes I was thinking along the same lines of getting the white ones.
I remember that last time I bought a brass replacement I had to take it back as the plate was slightly smaller than the original - something other visitors to this site should look out for !
Thanks again
Mick
It is currently Thu Jan 16, 2025 12:59 am
