by 333rocky333 »
Fri Jan 11, 2008 7:42 pm
You can get COOL FIT lamps , with aluminium back coating on the glass, these throw the heat forward and reduce heat going back through fitting,these are usually recomended with fire hoods or fire rated downlights to prevent heat damage within fittings.
Firehoods are recomended but will also increase the heat within the fittings.
This excess heat can cause the vents in the firehoods to seal up ruining the hood or fitting.
With the Hoods Check Instructions What Lamp They Recomend Before Buying.
The COOLFIT aluminium lamps are slightly dearer than standard lamps
Do not get COOL BEAM, lamps these force heat back through fitting ,these are used when lighting heat sensitive objects, and in your case will be worse.
