cellar floor drainage
6 posts   •   Page 1 of 1
smuglilal
by smuglilal » Sat Jan 12, 2008 1:07 pm
i have just recently lifted some flags in my cellar to find broken sections of pipe leading water to outside i have been told this is just ground water i am hoping to concrete floor is this true and as long as i dont block it can i concrete have covered with pea shingle at moment as advised
by htg engineer » Sun Jan 13, 2008 6:53 pm
Ground water will still build up in heavy rain, maybe evening flooding the cellar. I wouldn't advise just covering, best bet would be to renew a section of the pipe.
smuglilal
by smuglilal » Tue Jan 15, 2008 7:32 pm
thanks these pipes are only in sections so when heavy rain occurs cellar water spreads around pea shingle but never came above flags i have replaced sections with a long plastic pipe with holes in as the others were full of mud and clay as advised by a friend (not too sure of his reliability) i dont live in a major flood area and although the water is present it seems to just come and go and never rise am i ok to concrete?
by htg engineer » Tue Jan 15, 2008 9:02 pm
I'd be happier concreting now - once I knew the pipes were in place and in a good state of repair.
Would it not be best replacing the flags as then the pipes would be accessible ? rather than concreting ?
Quite difficult to advise without seeing.
What do you mean by "i have replaced sections with a long plastic pipe with holes in as the others were full of mud and clay" holes in the pipe ?
rosebery
by rosebery » Tue Jan 15, 2008 10:26 pm
Sounds like a French Drain. If I'm right don't concrete straight over it though - you'll just fill the holes up and it won't work! You'll need gravel below, around and on top of it to allow the water to get into it.
smuglilal
by smuglilal » Wed Jan 16, 2008 8:27 am
thanks for your help pipe is now fully covered with pea shingle and sand on top of that got to go with the concrete though not very good at flag laying thanks once again
It is currently Fri Nov 22, 2024 2:26 pm
