INSTALLING CENTRAL HEATING
afj24
by afj24 » Wed Apr 11, 2007 1:27 pm
HI
I LIVE IN A HOUSE WITH NO RADIATORS. I WOULD LIKE TO INSTALL SOME. I HAVE A GAS FIRE(DOESNT WORK) IN THE LIVING ROOM WITH A BACK BOILER(WORKING) AND A TANK UP STAIRS. HOW WOULD I GO ABOUT INSTALLING RADIATORS, WHAT SHOULD I BE ASKING FOR/EXPECTING FROM A INSTALLER
THANKS FOR UR HELP
ALAN
carhartt kid
by carhartt kid » Thu Apr 12, 2007 5:31 pm
Hi ajf24,
Its not hard to fit your own radiators if you've got a few basic tools and a bit of know how. I've just finished moving a few radiators around in my house and it was really quite easy.
I used speedfit/push fit connectors and plastic ploy pipe, both of which are fine for C/H. Theres a few handy hints on this site and you can buy all the fittings through the plumbing section in the toolstore.
Hope this helps!
thedoctor
by thedoctor » Fri Apr 13, 2007 6:15 am
The links were removed from the above post as external links are not allowed from the forum. This is because other sites have tried to use this forum for advertising.
