sealing around a window, making neat job of silicon
ramery2007
by ramery2007 » Sun Jan 13, 2008 8:29 pm
When some windows were replaced a few years ago, they used brown silicon around the frames, however the edges of the silicon are trimmed off (on the brick and frame there is a definate edge to the silcon) how do you get this effect ?
Would I put some masking tape on the frame and brick then use a gun to apply the silicon and after a few minutes - after letting the silicon partly dry, run a knife through the silicom and pull the tape off ?
Any ideas really.
stevenc1603
by stevenc1603 » Sun Jan 13, 2008 10:52 pm
You can get a tool that removes the excess silicon and leaves a neat edge, although you can also use the masking tape method you suggested too.
It is currently Sun Dec 22, 2024 12:38 pm
