LED Display- cooker
poppyo
LED Display- cooker
by poppyo » Mon Jan 14, 2008 11:11 pm
Hello. The circuit that has the gas cooker on it fused recently, it was fixed and is OK but the timer and clock display is lit up but is just flickering on 8888.
How can this be fixed?
Any help appreciated
Thank you
by ericmark » Tue Jan 15, 2008 9:14 am
Sorry you have not given enough information. Even then we may not be able to help I would look in cooker manual first and see how it says to set clock if that fails then look on internet on manufactures web site and if still nothing add to this post with make model etc of cooker. It may have damaged unit when it as you say fused. It may be fault on clock that caused problem in first place but not enough information to answer. Explain what you mean by fused and how it was fixed.
It is currently Fri Nov 22, 2024 9:08 pm
