STOPCOCK TAP
wayne7l
STOPCOCK TAP
by wayne7l » Thu Jan 17, 2008 9:38 pm
SHOULD YOU CONDERSATION ON A STOPCOCK TAP
by htg engineer » Sun Jan 20, 2008 9:00 pm
You do tend to get condensation on most cold water pipes and fittings, when the room is warmer than the water pipes. Ceramic toilet cisterns are quite bad for condensation too causing rotten floorboard etc.
Check when the room is at a lower temperature if it's dry then - it'll probably be condensation, not a leak.
It is currently Sun Dec 29, 2024 1:15 am
