Installing Air Admittance Valve
allbeaty
by allbeaty » Fri Jan 18, 2008 10:47 pm
I am going to extend my kitchen but the toilet stack pipe will have to be moved. I've been told that I could fit an AAV into the roof space of the new extension. My problem being that my toilet cistern is a copy of a Victorian High Level with internal overflow and the AAV will be above the Pan but not the cistern. Is this OK to proceed.
Many thanks to anyone who may be able to assist
Allan
uk_ducati
by uk_ducati » Thu Feb 14, 2008 8:45 pm
hi
i am a bit confused as to where the aav will be fitted as you say it will be going in the roof space but it will be below the high level cistern.
i am not 100 percent sure about where the water regulations state where the aav should be placed but logic would tell me as long as it is above the outlet of the toilet it should be ok.
hope this helps
paul
allbeaty
aav valve
by allbeaty » Fri Feb 15, 2008 7:25 pm
Thanks Paul,
The aav will be below the cistern and above the toilet outlet. The extension will be a single storey.
I have enquired with bulding inspecter and he has agreed that I can put a aav valve in as long as it is above toilet pan outlet.
Allan
It is currently Mon Dec 02, 2024 5:25 pm
