not gettin response at the end of other post. re mdf/ tiling
mikjayfay
by mikjayfay » Sun Jan 20, 2008 12:37 pm
is mdf safe to use at the end of a bath if well sealed with unibond sealer before tiling over using waterproof adesive and wetroom grouting?. :?
i have already put the mdf up and would not like to have to rip it out to put hardboard in as recomended on this forum..i have enough to do without that... but if not safe..looks like i will have to :(
kbrownie
by kbrownie » Mon Jan 21, 2008 8:41 pm
mikjayfay,
If sealead well from both side and all edges, should be okay to use but not my fav. If any water/moisture does manage to penetrate the board it will swell and could cause moment of tiles. i don't really use it but I have no doubt that it is used and under the right condition and installation is fine.
Regards
KB
mikjayfay
by mikjayfay » Mon Jan 21, 2008 10:36 pm
thank god for that.. and thank you for posting your advice :)
i have gone ahead and sealed it but not yet tiled that area..hoping for someone to give the advice you have just provided.
next time i will make sure to check if the material is suitable for the job [b]before[/b] using it...
thanks again
It is currently Sat Nov 23, 2024 10:37 pm
