Triton combi shower mixer
jebi
by jebi » Sun Jan 20, 2008 1:29 pm
Newcomer here, looking for help. I stripped the above because it was very stiff to turn, have refitted it and now not so stiff but water is not so hot when mixer turned to max. any advice would be appreciated
marrtin
by marrtin » Sun Jan 20, 2008 9:33 pm
A quick guess is you have put the control knob back on in the wrong position.
jebi
by jebi » Mon Jan 21, 2008 8:32 am
[quote="marrtin"]A quick guess is you have put the control knob back on in the wrong position.[/quote]
thanks m8, I'll try that
chris_on_tour2002
by chris_on_tour2002 » Mon Jan 21, 2008 11:28 pm
jebi, i had the exact same problem when i installed a similar shower in the bathroom of my old house - the problem was exactly as marrtin described. if you struggle, call the manufacturer technical dept direct they will talk you through the process as you do it, they are usually quite willing to help.
jebi
by jebi » Tue Jan 22, 2008 2:04 am
[quote="chris_on_tour2002"]jebi, i had the exact same problem when i installed a similar shower in the bathroom of my old house - the problem was exactly as marrtin described. if you struggle, call the manufacturer technical dept direct they will talk you through the process as you do it, they are usually quite willing to help.[/quote]
thanks chris will try that
It is currently Fri Nov 22, 2024 5:53 am
