Plastering below an exposed staircase
gbqgqc
by gbqgqc » Sun Jan 20, 2008 1:32 pm
What is the best thing to use to cover underneath a staircase with a bend prior to plastering. I tried to use plasterboard but could not get it to bend round where the stair treads turned the corner.
kbrownie
by kbrownie » Tue Jan 22, 2008 8:56 am
gbqgqc,
Sorry don't really understand your problem, could you please give a bit more detail can't imagine what it is.
Regards
KB
gbqgqc
by gbqgqc » Tue Jan 22, 2008 4:32 pm
My stairs have a 4 tread winder at the bottom i.e. you enter the stairs facing north and 4 steps later you are facing east. I want to plaster underneath these stairs and want to know what to fix to the stairs to allow me me to do this.
howard newhouse
by howard newhouse » Tue Jan 22, 2008 10:07 pm
I think i know what you are getting at, if you need the plaster board to "bend" cut thru the back of the board with knife, (not all the way thru just approx 2mm)cut multiple lines where the actual bend in the staircase is, as to fixing the plaster board to the stairs , you may need to fix some 2x1 batons first,failing that give me a call between 0900 & 1600hrs and we will see if we can sort it. Happy boarding HN 07917127751.
It is currently Sat Nov 23, 2024 8:26 pm
