Electric supply to garage
Jeff C
by Jeff C » Sun Jan 20, 2008 1:45 pm
I have an electric supply to my garage (which is about 20 yards from the house) this is from a 4 core armoured cable about 4mm. This supply has been in for some years. From the CU in the house 2 of the positive wires are from 2 different fuses, but in the garage these 2 positives seem to go to just one junction as do the 2 negatives. Would it be possible to put the 2 Positives in the CU together on posible a higher rated fuse, and then put a sperate small CU unit in the garage and adjust the fuses there to accomodate lights and sockets. At the moment I need to switch of 2 'fuses' in the CU unit to isolate any item in the garage
by ericmark » Sun Jan 20, 2008 6:51 pm
“Would it be possible to put the 2 Positives in the CU together on possible a higher rated fuse,â€
Jeff C
by Jeff C » Mon Jan 21, 2008 11:11 am
Hi ericmark
Thanks for the info - very helpful, cheers
Jeff C
Electrics : Question for ericmark
by Jeff C » Wed Jan 23, 2008 6:55 pm
Hi, you gave me some useful info regarding power to my garage, but you had a little concern about the earth, so could a 'seperate ' earth be provided by inserting an earth rod at the garage and runing the earth from cable from that rod to the garage CU
It is currently Tue Nov 26, 2024 2:35 pm
