Ceiling shower switch
Kenmac
by Kenmac » Sun Jan 20, 2008 7:25 pm
Hi all
My question is about a shower and were the 45 amp ceiling switch should be positioned.
Should the switch be external of the bathroom or were mine is, we have a door in bathroom which goes in to a small attic the switch is just inside this attic doorway so the position is outside bathroom but not on exit of bathroom. Is this normal?
Ken
kbrownie
by kbrownie » Mon Jan 21, 2008 12:54 pm
Hi Kenmac, when you say ceiling switch I guess you mean pull switch this has a pull cord on it and the cable termination are fixed to enclosure on ceiling. If so, it is okay to have it there, but can be installed in bathroom as long as the safety zones are complied to.
Regards
KB
Kenmac
by Kenmac » Mon Jan 21, 2008 8:47 pm
Thanks for your answer KB
Yes it is the pull switch and because its on the opposite side of a door outside bathroom I guess it is not in any of the zones therefore safe.
Kenmac
kbrownie
by kbrownie » Tue Jan 22, 2008 7:28 am
Kenmac,
If the opening has a door that closes it will be outside zones!
Regards
KB
It is currently Tue Nov 26, 2024 11:32 am
