by htg engineer »
Mon Jan 21, 2008 6:15 pm
There'll be bleed valves on the radiators, they will be at top left or right hand side. Either on the side of the radiator, or on the back of the radiator panel. Some are covered with small white plastic caps.
Turn off heating to bleed the radiators, and bleed until water appears. You may need a cloth to catch abit water.
