finishing laminate flooring in front of closet doors
islands01
by islands01 » Fri Apr 13, 2007 7:28 pm
I recently had laminte floors put in. The constrution guy never came
back to do the trasition pieces where the laminate floor and the wood
floors meet each other. Also he left a gap where the floor ends, and
where the closet doors are. I know how to do the transition pieces
where the two floors meet, but I don't know how to finish the gap
where the floor ends and where the beginning of the closest are.
Help!!
Debbie
thedoctor
by thedoctor » Sat Apr 14, 2007 5:00 am
Gaps in laminate flooring are usually covered by what is called a quadrant bead. The gap is left for expansion and covering it with the bead, in this case fixed to the closet, will allow the floor to move under the bead. Quadrand beads are available from all DIY stores and builders merchants and can even be bought to match most types of laminate flooring.
It is currently Sun Dec 22, 2024 12:09 pm
