Fixing door handles on hollow doors
Bernie2
by Bernie2 » Fri Jan 25, 2008 5:38 pm
The door handles on my doors are loose no matter how many times i tighten the screws they unscrew through use of the door handles. I have attempted to use plugs but because the door is hollow they just fall into the door itself :( Any advice would be gratefully received as I dont know what else I can do.
toptips
by toptips » Fri Jan 25, 2008 10:22 pm
have a look at inter screws to connect the handles to each other.you can get handles that are designed to be fitted with these fixings if you fancy a change.
Bernie2
Loose handles on door
by Bernie2 » Sat Jan 26, 2008 2:49 pm
Thanks for your assistance I will try what you have suggested and if i have any more probs will come back to you
It is currently Fri Jan 31, 2025 12:37 pm
