Hot water
gymark2002
Hot water
by gymark2002 » Fri Apr 13, 2007 10:20 pm
Hello,
Is it possible to run a pipe off of the Hot water tank that goes up into the Loft along and then back down again?
The reason I ask is I am putting in a Mixer shower and I already have a Cold water supply coming from the ceiling on the outside of the wall so I want to match it by running the Hot pipe along side it.
If this is possible can I take run off of where the over comes up, will turning on the shower create a vaccum and suck the water along the pipe?
Thanks for your help.
markp
by markp » Sat Apr 14, 2007 8:40 am
you mean take water from the vent pipe?
gymark2002
by gymark2002 » Sat Apr 14, 2007 9:54 pm
Yep take a feed off of the Vnet pipe to run to a Shower
gymark2002
by gymark2002 » Sun Apr 15, 2007 9:41 pm
Yes is it possible to take a feed from the vent pipe to run a shower?
markp
by markp » Mon Apr 16, 2007 5:31 pm
Yeah sure....but id be tempted to put a 'dog leg ' after the take off upto the vent!
It is currently Sat Nov 23, 2024 6:36 pm
