screwing holes into old walls
steve.perrins
by steve.perrins » Sat Jan 26, 2008 3:18 pm
Hello everyone , advice needed ..... I'm trying to fix a curtain rail and this involves drilling several small holes with a 6mm drill . However the plaster seems to be more like sand ! When i tap a rawlplug into the hole , the hole starts pouring out sand and the hole just gets a lot wider ... any ideas how to get round this ? is it a common problem ? .... hopefully yours .Steve.
kbrownie
by kbrownie » Wed Jan 30, 2008 1:22 pm
Hi steve.perrins,
your problem is that you plaster started to deteriate. If you don't plan to replaster, i'd consider using longer plugs and try hit something more stable further in.
Regards
KB
steve.perrins
by steve.perrins » Fri Feb 01, 2008 9:25 am
Thanks for advice KB , will try that this weekend ..... alternatively i might just glue wooden batten to wall using pinkgrip and fix curtain pole to that !
It is currently Sun Dec 22, 2024 2:04 pm
